1998 z28 bodywork
Old May 18, 2013 | 06:51 PM
68LS1WANNABE's Avatar
Default 1998 z28 bodywork
Just bought this 1998 z28 from a buddy. Car only has 128k miles but they have been pretty rough. Guy who he bought it from hydroplaned the car a few times. He thought putting the huge ricer wing on the back would stop the problem. Dumbass never thought to put some new tires on the car. Old ones were slick as onions. I'm gonna try to do most of the body work myself. I'm just looking for some advice on how to go about repairing the damage. I'm pretty sure i'll have to buy a new rear hatch. I wanna get rid of the wing anyway and go back to a stock spoiler. The driver side rear is busted. Drivers door has a hole in it towards the front of door. Drivers rocker panel is dented. needs a few dents massaged out of both rear quarters. I am planning on doing a base/clear paint job of factory white color. Not looking to sink a lot of money. Just get it looking decent and all one color.
Attached Thumbnails 1998 z28 bodywork-2013-05-18-18.21.59.jpg   1998 z28 bodywork-2013-05-18-18.22.08.jpg   1998 z28 bodywork-2013-05-18-18.22.20.jpg   1998 z28 bodywork-2013-05-18-18.22.30.jpg   1998 z28 bodywork-2013-05-18-18.22.49.jpg
Old May 18, 2013 | 06:58 PM
HumanNipple's Avatar
Call Mercer Motors and insist that you bought the car when it looked new and within a few days it looked like that. Demand money from them till you drive them nuts just because that sticker is on there.
Old May 20, 2013 | 11:35 AM
What are the best choices for body filler and primer. I've read that i need a flexible primer. I'm guessing that 3m makes something? What's the best way to fix the whole in the door? I can handle the metal work but know nothing about the fiberglass door.
Old Jun 4, 2013 | 09:06 PM
my main work is gonna be the rocker panels and the quarter panels. I don't have access to the weld on dent pullers. Only ones I have are where you drill holes in the panel then put the hooks in and pull out. Is that gonna work on the rockers? What's the best way to get these dents out that I cant get to the back side of?
Old Jun 4, 2013 | 10:39 PM
RS/SS 4.8's Avatar
14 Second Truck Club
Get ready to work. Body work is very labor intensive. Car looks very fixable but please buy or borrow a weld on dent puller. The dents that can be reached from the inside just use a body hammer and dolly and try to push the dent out from the inside. It doesnt take much force to move metal around you just have to know where and how to move it. You can buy a basic set of hammers from Eastwood or Harbor freight. Fiberglass is fun and if not done correctly it can get ugly. As for brand of body filler I have had no problems with Evercoat. Have fun.
Old Jun 4, 2013 | 10:49 PM
RS/SS 4.8's Avatar
Oh yea make sure there is no "foam" or seam sealer behind anything you weld, cut, torch or crap can get ugly quick. If you can get access behind that certain panel do so. The problem with the drill and pull method is your left with a bunch of holes and a weak panel.
Old Jun 4, 2013 | 11:34 PM
LoneGunman's Avatar
F***K THOSE wood screw dent pullers!!! They completely destroy the panel. Get a stud gun and do it the right way. To the OP, don't even mess with this if you don't know what you are doing. Take it somewhere and have it done right. Either that or keep the car until you die and be buried in it. That way no one else has to try to fix what you didn't fix the right way.
Old Jun 4, 2013 | 11:45 PM
scj's Avatar
scj
I hope you didn't pay anymore that $1000 for that car. If I were you I'd go spend 2k on a nice roller and swap the powerplant from this car considering everything on it needs work.
Old Jun 5, 2013 | 06:59 AM
I got nothing but time. It's gonna be a reason to drink beer and get out of the house. 10-4 on the dent puller. I've done a lot of metal work before. Just not on cars.
Btw if you zoom in on the drivers door pic you can see the hole in the door that I'm talking about. Right now my idea is to fiber glass a metal patch on the inside of the door skin. Then go on the outside and build the hole up with fiberglass, then body filler to smooth things out. I'm sure this is wrong but it's all I can think of.
Old Jun 5, 2013 | 07:28 AM
moderate Z28's Avatar
That's a tough spot to fix RIGHT on that quarter panel. Just use fiberglass mat on the inside of the door, then fiberglass reinforced filler on the front to fill most of whats left, and finish with evercoat body filler. Man that pic looks like Georgia alright!
Old Jun 30, 2013 | 10:24 AM
I'm trying to get the rear quarters right. Can anyone post a pic from the rear of the car looking down on the hatch. I'm trying to get the gaps right, how wide should they be? 1/4"? Also does anyone have some measurements on the factory quarter panels. Im trying to see how much if any they are off. I was looking for some measurements from quarter panel to quarter panel at the factory weld joints that are under the weather stripping.
Old Jun 30, 2013 | 11:46 AM
stevesfbody's Avatar
**** that ****
Old Jul 29, 2013 | 07:43 AM
dkkc's Avatar
body shop supply house will have two part repair glue for ridged plastics for the door, requires a special gun to apply but u can push out an mix on board....as for dents if u use a pull hook just make light pulls in each hole going back an forth till its works out.. moving metal slow is the key to not stretching the metal...then cover holes with evercoat short strand fiberglass filler ( first coat its water proof an will stand the test of time )...it will last as long as any other repair..then top coat with high quality filler such as rage from evercoat..sands easy wont pin hole...hope this helps
Old Jul 29, 2013 | 07:48 AM
dkkc's Avatar
qt gaps typ. are 1/4 inch at hatch an close to that at dr gap...as for stud guns yes great tool... but one time use kinda costly...an weldind a stud on bakes finish from back side an cousing oxidation. rusting much faster than surounding metal...so its a toss up actually...good luck an enjoy
Old Jul 29, 2013 | 11:23 AM
MasterTomos's Avatar
lmfao
Old Aug 8, 2013 | 10:48 PM
don't know if it is gonna mess things up in the long run but I have gotten most of the dents popped out by getting them hot with the heat gun then using a can of computer duster to freeze the metal. Most of the smaller stuff just popped right out. I saw it on youtube and had to try it.
Old Aug 10, 2013 | 12:28 AM
JDEP162's Avatar
Originally Posted by stevesfbody
**** that ****
I scrolled up this thread from the bottom, when I got to this comment I thought wow what a dick. Then I looked at the pics of the car. I now agree with this comment. Sorry dude, pile of crap. Sell it to a 17 year old punk and be done
Old Aug 10, 2013 | 12:03 PM
Damn. Didn't know it was such a crime to work on your own stuff. Gotta pay somebody to do everything for you huh. Our sport of hotrodding, and it is a sport, is supposed to be about working on your own rides. Sweat, blood, and beer makes cars fun to me. I got a jy hatch for $100. Less than $200 in paint and body fillers. Not trying to build a show queen. Just a fun street rod. If you guys have those deep pockets to pay a man to fix your stuff for you that's fine, but you will never have the satisfaction of getting your hands dirty and know that you built your own ride. BTW i will always try to be a 17 yr old kid at heart. No fun in being a old fart.
Old Aug 10, 2013 | 12:20 PM
rickybobbyss's Avatar
decent ride fix it up,,and its still faster than any sbc car
