Got My Roof Painted, Need Advice. *PICS*
#82
My body guy is suggesting to grind out the sail panel, along all the glue lines, down to the base. Lay in some fiberglass filler/primer, etc...and then prime and paint. My question to him was, yes, you can see some of the glue lines, but he can't possibly ensure that he got all of the glue....so I wonder if it would actually work? Then he said it would be 16 hours of work x $70....$1120. May be cheaper and more predictable to get a new panel in.
#83
1) The glue already got into the fiberglass. Unless you plan to grind all the way through it you probably won't get it all.
2) You can get a brand new sail panel for half that!
#84
LS1Tech Administrator
Received 1,695 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Or if you feel like looking for a used panel, that's the cheapest option.
#86
#87
Don't be like me; fix it right the first time.
#88
maybe I missed it but is there a certain part# for the urethane to use when replacing the panel and do u need to prime or coat the under side of the new panel before installing it? ive got the same problem my local yards got 7 lt1 hardtop cars they said I can get the roof for 59.00 but I gota pull it so the cordless sawzall and me are about to go on a date!
#89
Bubbling Sail Panel Issue for Dummies
and in the very first post at the bottom it lists the glue that is approved for use:
As for the prep, I'm having my roof worked on now. I'm having the shop sand the underside of the panel and prime it for me and I'm going to run it like that.
#90
I had 3 98 camaros at one point, all of them had the fender bulge but they all had the brace. They all got them from the crappy lifts that you drive over that lift the body. Consensus seems to be they were just re using the old supply for lt1 cars and when they changed plastic suppliers they did not renew the part because it never really worked anyways
Another annoying 1998 fbody fact, only year with the specific designed gas cap. Why they changed the design at the end of 97 and then again in 99 I just don't get.
#92
Ok, so thankfully I found this forum about a month ago.
Back in Nov '14 I paint the roof on a 2002 Firebird not knowing that there were issues with the roofs on these cars. In Feb the customer brought it back to me saying the paint was still bubbling. I proceeded to sand down below the bubbles when I realized the roof was fiberglass. I had previously assumed that it was metal since magnets stuck to it. So once I did a search for fiberglass Firebird roofs I came across this forum and found out why the paint bubbled. After about 2 weeks of trying several different ways to remove the donor roof without breaking it I finally removed it from the roof frame where the junk yard cut it off. On the customers roof I just went to town with a linoleum knife and 3" cutoff wheel and cut around the inside of the glue. Figured it will be easier to cut through the urethane with majority of the roof gone.
Now to my question. Does the windshield molding have to be removed to cut the front urethane off? I have read that some say there is no need to remove unless it is already damaged or dry rotted. Thanks
#93
A little late but I'll chime in. The windshield molding doesn't have to be removed. You can see from the one picture I posted that the front edge of the roof is slid underneath the molding and then laid down. I got a new molding for like $20 from the windshield guy.
#94
I searched and can't find much info on how exactly to get the full hardtop roof off of a donor car without damage. Post #23 and #28 in this thread have a little information, but not enough for an amateur like me.
1. I have a hardtop donor car. Is it easier to get the plastic top off the car, or should I cut the whole metal clip off like this thread so I can work from top-side and underneath?
2. My local GM Body Shop suggested I talk to a windshield shop. This post mentions a windshield guy. I guess that's because of the piano wire with handles. Also mentioned is an air tool. Where can I get these tools?
3. How do you get all the old urethane off the donor plastic top and car frame?
4. Are those triangular side pcs at the bottom glued on? How do you get them off?
Thanks for any help, guys.
Great thread, by the way.
#95
They are put on with double sided tape. They can be a pain to get off though, so if it's in your budget I would just order some new ones. The reason they are a pain is because they are usually sun baked and brittle. I was able to reuse mine, but it was mostly garage kept and I was extremely careful when I pulled them off.
#97
It was much easier to have the entire donor roof off the car and on a stand, there's not the rest of the car in the way when you're trying to take off the roof.
Just take your time, it is doable it just takes patience. The best tool I used was the wire with the help from the windshield guy. Basically just two wooden handles and a piece of wire and we slowly saw'd back and forth. We also used an air tool with a sort of cutting bit, hard to describe it and I'm not sure what it's called. Ended up not making the job much easier but we were learning as we went. If he comes around any time soon I'll try and take some pictures of it.
#98
Hello guys. I have a 02 Camaro Hard top. Now the top started to have bobbles everywhere and to find a donor car in my area is not to easy. My car is a average 02 Camaro that I not want to invest 1k in the a new top.
Now if i strip all the paint out and prep the top and them wrap the top with vinyl paper, the bubble problem can stop?
#99
