Another rust thread...
I've researched two products, POR-15 and Rust Bullet. POR-15 is the mechanical blocker, painted on the rust. Rust bullet is chemical, and needs to be applied to bare metal. If my understanding of the two is correct, which of those two is my best option? Is there a third option? Could I do a mix of both? Rust bullet as a base then rough up and apply POR 15? Anyone whose dealt with this before have any recommendations.
I have an angle grinder and can attach a wire cup. I'll be doing all the work myself, and don't really want to have to take it in anywhere.
Good thing is you probably don't have it rusting thru from the other side given it is the floorpans. Although the subframe rails could be (my 98 rusted on both sides of those pretty badly).
Not trying to scare you but just wanted to be sure you're prepared.
Also, should I try to do the dual rustbullet por-15 treatment? Or just wirewheel and apply the por-15. Would It be a good idea to spray the por 15 all over the frame rails and the inside of them as well? I keep thinking I'm going to seal in residual salt or something. Am I good to just spray it everywhere on the bottom? Or will it have problems bonding to the paint?
When I get my car repainted I want to get the underside all coated with something like POR-15. I don't drive my car in the winter but it still sees the occasional rainstorm or other wet weather.
Still wondering what everyone thinks about the dual rust bullet/por-15 treatment. If I'm taking it down to bare metal, i figure I might as well use the rust bullet. Then use the POR-15 to blanket cover everything.
Doesn't seem like wire brushing and applying por15/rustbullet is going to be solution. Am I going to have to cut this out?
Also, would it be best to try back-plate welding the gap shut? Or cut and fit one then weld it in?
I guess I've also never seen this, but what gauge metal is the floor boards?
In your case I would cut out the rusted area and replace it. Also you can get CPS for the frame rails and spray after welding up repair area.
