curing vht paint
Old Aug 3, 2015 | 11:35 AM
HappySalesman's Avatar
Default curing vht paint
So I want to paint my stainless headers (once I get them) with VHTs ceramic coating (if for nothing more than to reduce the under hood temps).
However I know you have to cure the paint by chucking it in the oven, but LTs sure as hell won't fit in any house sized oven lol.
Anyone have any suggestions/workarounds for this?
Old Aug 3, 2015 | 07:30 PM
bobfig's Avatar
install them run the enging for a few min to warm them up just not full operating temp. do it like 3 times.
Old Aug 4, 2015 | 07:48 AM
SlasherVRGR's Avatar
When I did my pace setter shorties for my 3800 car I had my old lady toss em in the oven while i was at work for 30 mins on 150, cool, 30 mins on 250, cool, 30 mins on 350, 450, and 550.
Idk if this actually did anything, but they held up for the duration I had the car afterwards.
Old Aug 5, 2015 | 12:28 PM
imma_stocker's Avatar
Clean them of all oil and grease. Hang them from a wire where you can paint them.
Let them DRY as much as possible while hanging. The ceramic won't cure until they get hot but they can dry enough to survive a careful install. To speed up the process I've used heat guns and space heaters.
Use reasonable care when installing then do the heat cycles to cure it.
Old Aug 6, 2015 | 02:23 PM
Would hitting the pipes with a torch help cure them a little bit before install? Don't want to go paint them then nick it sliding it in place and have to re-do the whole thing.
Old Aug 6, 2015 | 03:43 PM
Not a torch, too much direct heat in a very small area.
The coating will dry enough to handle, it has to completely dry before handling anyways.
Old Aug 9, 2015 | 11:05 AM
WSLN 6's Avatar
I have had good luck curing them with a heat gun until everything is nice and toasty. The flameproof stuff has been the most durable, even on turbo exhaust housings.
Old Aug 9, 2015 | 03:22 PM
Hmm. I do have a heat gun that'll go up to 1100 degrees... I'll give that a shot. If nothing else I'll look into renting a huge barbecue lol
Old Nov 9, 2017 | 07:11 PM
5.7stroker's Avatar
Back from the dead....
Highest I could get my cure is 180F in a cardboard box with a hole cut in it and a heat gun going for 30 min. I need to get the primer to 600F for 30 minutes prior to top coating. Time to find a big oven at a powder coater. For those that used the heat gun on the VHT flameproof primer, did it cure well enough to be topcoated with the VHT flameproof aerosol?
Old Nov 9, 2017 | 07:36 PM
farmington's Avatar
I think that powder coat ovens only cook at 400. might not be hot enough. Personally, I have cheap ebay stainless headers on my car and they're probably 8 years old and still look really nice.
Old Nov 9, 2017 | 07:58 PM
I say spray' em, dry 'em, bolt 'em on, and run 'em. The heat of running them will cure it as well as is needed.
Old Nov 10, 2017 | 02:10 PM
What are you using a hair dryer?
FWIW, to speed up these jobs in the shop I use torpedo space heaters that pump out 150,000 BTU
Old Nov 10, 2017 | 02:26 PM
5.7stroker's Avatar
Nope a heat gun but apparently one that doesn't get very hot. I found a location with a big oven that goes up to 650F so should be all good. This paint has a specific cure cycle to it.
Paint must be completely dry before curing
Heat to 250°F (121°C) for 30 minutes
Cool for 30 minutes
Heat to 400°F (204°C) for 30 minutes
Cool for 30 minutes
Heat to 650°F (343°C ) for 30 minutes
Old Nov 11, 2017 | 01:47 PM
dreadpirateroberts's Avatar
i say paint it white.
Old Feb 4, 2025 | 06:35 AM
68Riviera GS's Avatar
Default Heat gun results
How did the primer turn out after using the heat gun?
How did you go about doing it (what process did you use)?
