changing color on hood
And once I figure out how to sand the entire surface, do I want to go on to 400, then 600 before applying any primers or sealer?
I don't know about needing another sealer coat, I'll let the experts weigh in, but since you are painting over an existing job that should have its own sealer, I'd think you can skip straight to primer. The underside of the hood looked a little light though, so maybe you'll need to create a base there. Once you lay the high-build sanding primer down, then you can start to perfect things and get surfaces blocked out. If you wish to hold creases in your hood, like the center spline or the faux intakes, you can use vinyl tape like they use to mask off flames. Get a few widths, as fatter will make straighter edges for you, but thinner can take tighter turns. Any automotive paint store will carry this tape.
Eastwood says there 2K urethane is a "sandable primer which allows for leveling out imperfections typically sprayed over epoxy or self etching primer."
Polyester primer they say "Think sprayable body filler"... The trick the pros use to get laser straight body panels and a killer paint job in the end.
Sooo, I'm still confused on which to use.
Like I said in the beginning, this VFN hood looked really nice before, unfortunately it was red instead of maroon already. Which brings up another concern ... its fiberglass. Anything special or different procedure for that?
