Door Sag
I took my 2001 WS6 Vert into a Body shop to have the door rollers replaced because they were going bad and starting to rub on the fender. While the car was there, they discovered it had been in an accident (no carfax). I got the car back 2 months ago, with everything ok. Then 2 weeks ago the door started to pitch the fender again. So she went back to the shop today and they shimmed the fender. The also stated "another thing to think about is that the convertible Firebird/Camaros (convertibles in general) are not the most rigid of vehicles. I can explain more when you come to get it."
Is this BS?
do I need to find a New Shop?
Can I do anything?
would Subframe connectors help?
Thanks,
The latter problem (a single screw) caused me a ton if issues with the alignment of the fender to the door. Another thing that also screws up the fender alignment to the door is the bottom attachment to the body by the door. There are two screws that attach to a plate jutting downward right near the jacking point. Grease monkeys at "mechanics" shops, tire shops, etc. will skip putting proper blocking on their lifts to hit the jacking points or will mistake this plate (and the fender attachment) for the jacking point and will lift the car on it. (I think this mistake happens more on the non-T/A cars and ones without ground effects.) This causes the fender to budge and will eventually break the attachment necessitating nasty repairs.
I just got it back fromt he Body shop, which is next to a cement plant and Coach a High School Soccer team and we been really busy with Tournaments and Playoffs. Not sure I I got all the right angles you were looking for, can take more tomorrow. I did notice the the new roller, which rusted quickly has a gap that appears larger than the passenger's side.
From this angle, you can see the fender sticks out a little more at the bottom. This is from improper jacking. This isn't that bad. Mine stuck out 3/4" before I fixed them...
This tab has been bent over and someone straightened it up a bit. (So the car has been jacked here in the past.) There is a makeshift bolt towards the rear part of the late and it looks like the steel plate is wrinkled from the bending.
I assume this is the driver's side. It looks pretty good and in the place it should be. I would guess your passenger side might have a little bit more of a bend to it. (The fix is easy. Just unbolt the fender from the plate, bend, and then bolt back up. ... Then watch it whenever you take the car to a mechanic, take pictures before hand, and then hold them responsible if they do it again.)
