HOK or PPG Paint?
. The paint on the hood is just about 3 years old and I think it should hold up longer then that. THe painter has helpers do work and I think they did the last one...who knows but I bet he won't do anything about it. Im pretty disgusted with the work done
BTW Styker I have the paint code for the Porsche. It is Orangerot and it's L198
If you are still needing some of that paint for touch up I can mix you up a batch. Not sure how much you are needing but I will most likely have to make at least 3 ounces to get an accurate color match for the color you are talking about.
My friend and I were talking about repainting my car and the color I should go with. He suggested a red similar to yours but I didn't care for the idea too much. After seeing your car I think I would really like to do something similar. I'll have to start looking at a book to pick the exact color I want
so when I go to touch up the back half of the car, how should I do it? Wetsand the whole half with 800, then mask the stripes (they're fine.) then paint the entire back and blend into the doors, then unmask and clear the whole back including the stripes? I'm kinda worried about it sticking out, but I dont want to repaint the whole car.
. I will be getting rid of that bumper with the gfx soon so that will be one of my troubles gone and this time a different painter doing the work. I'll PM you about the paint.
Since the car is still freshly painted I would just work out the bad areas finishing with 600 grit on the entire panel and then rebase and stripe the entire panel. If you feel comfortable blending the base you can do that as well but if its a recent job and an out of the can color you shouldnt have and color match issues as long as you spray the same coats as you did before.
