Painters tips: Painters Please Share
And another tip on flow coating: It is best done after the LAST coat of clear has cured and been wet sanded. Then you come back with the over-reduced clear and apply 2 wet coats to give it a super smooth finish. HOWEVER...this process should be used for show cars only that don't see too much sunlight. When you over-reduce the clear, you are decreasing the film build (mils) of the clear. Clear coat is UV protected ONLY at a certain film build. Any thinner than the recommended film build, the clear will fail over time (i've seen that happen in as little as 6 months in our Texas sun.)
Clear
let it tack
clear
let it tack
clear
let it cure
wetsand
clear
let it tack
clear
let it tack
clear
let it cure
wetsand
clear
let it tack
clear
let it tack
clear
let it cure
wet sand
buff
this is alot of work and the right way to do this for a super wet, showcar look.
Quit being lazy
Clear
let it tack
clear
let it tack
clear
let it cure
wetsand
clear
let it tack
clear
let it tack
clear
let it cure
wetsand
clear
let it tack
clear
let it tack
clear
let it cure
wet sand
buff
Quit being lazy
Id clear it with three coats, let it sit overnight. Sand it with 600 then clear it with three more coats. Then id cut and buff.
I believe with that many coats the solvents are never going to come up. Which will cause problems later.
+1
the clear will fail.
