Removed my stock bodykit, need help on removing the black clips
. I just removed my stock "RS" kit from my z28 however, how can i remove the metal black clips (the one that holds the kit to the car itself) away ? It seems like it was permanent drilled on the bottom around car. Thanks in advance
Originally Posted by Whistler
You're going to have to fill about sixty holes in the bumpers and rocker panels if you want to remove that.
heh. i just did this yesterday. take a FAST drill and get a bit bigger than the side of the head and it will tear them right off, also, an angle grinder works much better for this because something those dam rivets spin.. use the angle grinder. u cant even see the holes really... any idea how to get off the wing? haha
