alternative solutions to the roof bubble issue?
Old Aug 3, 2007 | 05:00 PM
Loochy88's Avatar
Default alternative solutions to the roof bubble issue?
I simply cant find any dealer who will even partially assist me in replacing my roof with a pretty bad roof bubble problem and theres no way i can afford the 1000 dollar repair at the moment...
I've been thinking, maybe there's another solution.
What would happen if you sanded the roof down to the raw material the roof panel was made out of, and then let it bake in the sun for a period of time and then had the roof repainted? It may still bubble a little, but would it at least improve the situation at all? There cant be an infinite amount of gasses/glue coming through the roof, can there?
Also, what about a layer or some sort of thin layer of impermiable resin/filler/other material on the roof (maybe after doing the other step i mentioned above) and then painting?
If youre laughing at these ideas i apologize I'm no paint/body man. I'm just thinking out loud...
Old Aug 3, 2007 | 05:15 PM
platinum1's Avatar
hey if you ask me no idea is a stupid one.i cant help you because i honestly dont have a answer but good for you for trying to come up with some ideas
Old Aug 3, 2007 | 07:53 PM
stockerws6's Avatar
I only have a few small ones but they are bubbling pretty bad. This is probably a dumb question but what about putting a small pin hole in the bubble (is it just fumes under there that will leak out or is it actually glue that will seep out)? Would that help any or just make it worse? Sorry to hijack!
Old Aug 3, 2007 | 10:32 PM
Loochy88's Avatar
it will get worse, and youll eventually end up with 100 pin holes. no thanks
Old Aug 3, 2007 | 10:44 PM
02silvaZ's Avatar
GM should replace every one of these since their dumbass is responsible, no if, ands, or butts
Old Aug 3, 2007 | 11:25 PM
Jpack's Avatar
When I did my t top conversion I bought a brand new one shipped to my door off ebay for 150. Beats the 480 gm charges for them. A guy on there had 12 of them and it was a best offer deal. When putting the new one on I just used windshield adheasive. Worked great and no issues.
Old Aug 5, 2007 | 01:29 PM
ShortChevy's Avatar
Not to hijack to far but does anyone have a good close up picture of this bubbleing. I guess my car just don't have it but it seems to be extremly common, so I just wanted to know what to look for.
Old Aug 5, 2007 | 03:52 PM
YOOFORMULA's Avatar
I tried that and the bubbling still came through the panel. Its the glue under the panel so no matter how much you grind unless you change out the adhesive it will still bubble.
Old Aug 8, 2007 | 12:51 AM
makWS6's Avatar
Yup, thats the problem, the glue!
Old Aug 8, 2007 | 01:20 AM
wzup1000's Avatar
is the roof bubble just common with the 99-later models? I have a 98 and dont seem to have any issues...
Old Aug 8, 2007 | 01:56 AM
stevethepirate's Avatar
yeah, its just the 99+ cars.
Old Aug 10, 2007 | 08:42 PM
03 BUSA's Avatar
I have a 98 and it does it. What I do about once a year is wet sand and then hit it with a medium cutting compound then machine wax and polish. Seems to work for a while.
Old Aug 10, 2007 | 08:51 PM
Loochy88's Avatar
you must not have the same problem we have, cause wetsanding would in no way help. it actually pushes pencil eraser sized patches of paint up from the car when heated up, then it will go back down when they cool off. it leaves the paint looking all wavy and shitty. how would wetsanding help that?
Old Aug 11, 2007 | 10:25 AM
Jeremiah's Avatar
The only way to repair the problem is to replace the top.
There is nothing you can put on or over the top to stop the problem, it will blister through decals also.
M Mecham is a Feb 98 production and has no signes of the problem. My 30th T/A and my 01 SS were replaced though.
Old Aug 12, 2007 | 05:36 AM
MasterV8's Avatar
Hoping to see if i can get mine replaced soon! fingers crossed
Also posted in the stickies section for any help "hint"
