Rattle canning engine bay.
Here it is now
good luck though if you do it.
I used the paint from autozone that comes in the little cans for about 5.00 a can. I sanded everything, primed, then painted wet sanded and painted again then after it cured wax the heck out of it.
I get tons of compliments on how clean it looks. It is a 98 with 130,000 miles, I took on the painting due to the battery leaking acid on the passenger side wheel well and damaged the paint all the way down to the metal.
I'm looking for a semi gloss or flat black color.
Was all would be needed for prep if you've used rust-bullet/por15 or other similar products in the past. Just sand, scuff and spray away or just spray on top of the base.
I sanded, then primed, then sanded, then wet sanded then painted again, then after it cured I waxed it. I do not know if what I did was the best way, it is just what I did.
Why?
