Window Xperts advice needed
Now for the re-install in a different hatch. How do you get the sealant off of the glass? What kind of window sealant (exactly, because I've seen a lot of different kinds) should be used? I'm assuming Liquid Nails wouldn't be the way to go!
I plan on using wooden dowels to ensure I get the even spacing around the edge, and a buddy and I are hoping to get this done before it gets too cold here in TN...or is it already? ANY help is appreciated because the cheapest quote I could get was $120 and there was no gaurantee that they wouldn't break the window or ruine the rubber strip. Quite the professional establishment, huh?! Last time a friend went to a shop to have his windshield removed because the sealant was leaking, the shop pushed the glass out with their feet!! "Well we didn't gaurantee the glass wouldn't break." Thanks a LOT! Swat
there a spray they make that dissolves the silicone that u can get, at my shop we had this blade that looked like a putty knife that u put on a saws-all and after the silicon start to come apart u run the saws-all around the edge of the glass and it cuts thru the silicon then u can pull the glass out, but some times u got to run a piece of wire threw the edge to get it cut all the way around.
you can use liquid nails to install the glass on the new hatch
