Can I move the fender at all? Hood is too close..
I put a Sunoco pin on hood on my 2002 Camaro and its hitting the passenger fender at the top near the cowl. The gap is pretty tight on the drivers side, so I can't just move the hood over. I need to pull the passenger fender "out" somehow. Is that possible?
for the fender loosen the bolts and pull the fender back a little bit. for the hood loosen the bolts that are on the hood and push the hood over a little. if your gunna try the hood method i recommend someone helping you only do that the hood doesnt slide down into your cowl panel.
if you look thru your door when it is open you will see the hinge for the fender, you need to loosen the bolt and pull the fender out a little bit then tighten it back down, but if i remember right you have to almost completely unbolt the fender and go in thru the top to get to the bolt.
