yea.. you dont have to remove that quarter panel to do the job. To remove the quarter panel its about an 8 hr job involving taking half the interior out, drilling all the spot welds, cutting glue lines on the edge, Refitting the QP, Spot welding all the spots, Big PITA. I work at a body shop. Im guessing where your hand is there is a dent correct? If so all they have to do is grind the area down where the dent it, use a spot puller, then apply bondo, sand, apply another layer of bondo, sand it, prime it, sand the primer, another coat of primer, then watersand the area and paint. If there is no dent its a pretty easy job. They will just have to DA Sand the area and put bondo. And your all set. The tail light,inner quarter skirt, and the antenna cap and post, and loosen the right side of the bumper, are the only things that are going to have to be removed.
