Base coat question
Old Aug 20, 2008 | 09:29 PM
jlam411's Avatar
Default Base coat question
I just put 3 coats on my front bumper. I was wondering if the base coat is to be wetsanded before the clearcoat? Also is the base coat once sprayed not suppose to be completely smooth?
And while i am at it has anyone else noticed that for the light pewter metallic color that the same color code from the paint store seems more silver than the tan color? just me or an issue with the paint?
Old Aug 20, 2008 | 09:34 PM
bdyman's Avatar
the only time you wet sand base coat is if theres is dirt , or sand scratches , but you never sand and leave it before clear
when its sanded then reapply base tack it off then clear it
Old Aug 20, 2008 | 09:37 PM
jlam411's Avatar
so is the first few layers of base suppose to have a light texture to them? or be completely smooth? there is no dirt on it so i am good there
Old Aug 20, 2008 | 10:21 PM
Marc3.4V6's Avatar
If it is textured, you're spraying it wrong. Not to be mean, but I don't think you should be painting at all from the questions you're asking, you have a lot more learning to do before an attempt at painting.
Old Aug 20, 2008 | 10:33 PM
jlam411's Avatar
yea well i go by the fact you will never leanr unless you try. plus i have studied and read and asked pros for the last 3 weeks about the process. i am just asking these questions to recheck myself. and i am sure if there is any texture then the air pressure was wrong. i know that.i just need to know waht to do bout that. to lightly sand it or to leave it clear it then wetsand it. i asked a question for a answer not to be criticized.
Old Aug 20, 2008 | 10:55 PM
Marc3.4V6's Avatar
You asked if it is supposed to be textured, I answered your question. If you don't want to be criticized, too bad, you need to get forum insurance. You're in luck, though, I offer it at a low rate. Contact me in the morning, I accept paypal.
Sand it with 800 or 600, depending on how bad it is. Wipe it down, tack it off and reshoot your base. Sometimes when wet it may look like it has a bit of orange peel, this is fine as long as it is not excessive, it will flow out with the clear.
Old Aug 20, 2008 | 10:58 PM
jlam411's Avatar
Thank you thats what i was looking for. But since you are all knowing. How would you suggest the spray gun settings be set? a guy at a paint shop set mine so it may have been nudged on the way home. i dunno, but i like to do everything myself perfect or not.
Old Aug 20, 2008 | 11:19 PM
Pheonix's Avatar
29 psi shoud do fine for a gravity fed gun. Make sure you are mixing the base and reducer to the correct specs.
Old Aug 20, 2008 | 11:22 PM
jlam411's Avatar
everything is mixed correctly, and i have the right psi for said spray gun. since it stippled a small bit shoudl i use more air less paint or more paint less air. thats what i meant to ask
Old Aug 20, 2008 | 11:27 PM
Pheonix's Avatar
By stippled you mean splittering like its spraying too dry?
Old Aug 20, 2008 | 11:28 PM
O-townLS1's Avatar
As far as the gun goes, make the pattern as wide as it can be vertically. Loosen the **** that controls the needle to let the paint through. Hold the trigger down as hard as you can and tighten the needle until you feel it push the trigger back out. Set your air tank to 38 - 42psi. I prefer 38 but thats just me.
Old Aug 20, 2008 | 11:29 PM
Pheonix's Avatar
From the sounds of it its spraying too thick so it might not be comming out the gun correctly try adding a bit more reducer and see if it sprays better on a piece of cardboard or something. Or it can be also what O town stated about the trigger needle. Make sure you have a full trigger pull.
Old Aug 20, 2008 | 11:43 PM
jlam411's Avatar
thanks for the help guys i will try that tommorow. i believe i have mroe than enuff paint to keep trying. i might have alot of base coats on but at least i am learnign to do sumthn new.
Old Aug 21, 2008 | 02:12 AM
O-townLS1's Avatar
That is the only way to learn!
Old Aug 21, 2008 | 09:09 AM
redramair98's Avatar
remember there is a time frame to topcoat over the base you already put down, make sure you are in that time, if not you are goin to have to sand it anyways
Old Aug 21, 2008 | 10:57 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Depending on the paint manufacterer you have a window in which you have to apply the clearcoat usually up to 12 hours is safe after that you will need to scuff the base put another coat on then clear.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Aug 25, 2008 | 10:18 PM
Nauty99SS's Avatar
#1 . the first time i painted something on my car i got the same effect .. my poblem was not enough air pressure ..38 to 42 psi i like 40 .. sounds like the flake in the paint isn't laying down .. hence low air pressure .. dont use to much pressure as i was told could cause a similar effect..set the gun like O-townls1 said .. good start
#2 . my car is the same color and it looks more gold to me and kinda oily looking before mixing with base maker
#3 hope this helps , and ...practice ..practice ..practice.. and keep lots of laquir thinner on hand
By Brett Foote | 2026-06-04 05:00:17
