Lowest Trans Am in the World - Radical Thinkers Only!!
Old Nov 26, 2008 | 09:01 PM
  #321
JasonWW's Avatar
Originally Posted by IFRYRCE
If you're chopping the top, how are you going to get rear glass? IIRC, our rear glass is one of the most complicated pieces of automotive glass to date.
There's old school techniques for that.
1 Dont run a back window (camera)
2 Adapt a window from a different car
3 Make a small, short window from flat glass
Old Nov 26, 2008 | 09:09 PM
  #322
JasonWW's Avatar
Originally Posted by crossroads
can you put up a pic of the final design without the rear spoiler, curious what it looks like
It looks like crap with the low, long shape of a chopped car.
Old Nov 27, 2008 | 04:12 PM
  #323
Brian2006's Avatar
I think it's time for me to finally say this.
You've been talking about this for years. When are you actually going to do it? Skeptics may arise since its been so long
Old Nov 27, 2008 | 05:34 PM
  #324
JasonWW's Avatar
What?
You need to check your time line. This thread is 2 months old.
Old Nov 27, 2008 | 06:56 PM
  #325
Juiced's Avatar
Use a chopped lexan rear and giberglass hatch lid, then extend with fiberglass to fit properly
Old Nov 27, 2008 | 08:57 PM
  #326
Brian2006's Avatar
What?
I've seen many posts where you talking about putting airbags on your car in the appearance section for a long time.
Old Nov 27, 2008 | 09:09 PM
  #327
Flaring Afro's Avatar
Unless you're a midget, you aren't going to get a car that sits 52" high stock to sit 35" high. Thats just not possible, unless like the batmobile you lay forward as you drive...
Old Nov 28, 2008 | 01:35 AM
  #328
JasonWW's Avatar
Yeah, so are you getting them mixed up? This is not an airbag thread.
Why do you care when or if I do it? If you want it done on a deadline then pony up a few grand and maybe that will happen. As it stands, I'm doing this with my money and on my time. I can't give anybody any guarantees.
Old Nov 28, 2008 | 01:47 AM
  #329
JasonWW's Avatar
Sure it's possible.
BTW, since I want to run 26" tall front tires and I don't want them poking through the hood, I'm not going to remove 3" from the bottom of the car like I had originally wanted to. So it's going to be about 38" total.
Take the old Ford GT40 for example. At ride height it was 40" tall and it probably had 4" or 5" of ground clearance. Now if you were to modify the suspension so the body could drop all the way to the ground, the car would be 35" or 36" tall. You just sit on a reclined position which I already do. Your butts going to be really close to the ground and your head will be pretty close to the thin roof panel. Now you won't be able to wear a cowboy hat or anything but it should still be comfortable to drive around in.
There are even production cars similar in height. Look at the Lamborghini Coutach which was 42" at ride height when it came out. It has the engine in the back and short front tires which help, but I can get by with my current design.
The Lotus Esprit was another low car. It, the GT40 and the Coutach all had the engine in the back, BTW. It's just tricky squeezing the engine up front on a real low car, but the f-body does have 2 things working in it's favor. One is a short engine in the LS1 and LT1. Second is that the engine is tucked pretty far under the dash.
Old Nov 28, 2008 | 08:38 AM
  #330
Raleigh TA's Avatar
Default D@mn those 1 and 8 plugs
I think this is the first time I have seen our engines tucked deeply under the dash stated as a positive.
Old Nov 28, 2008 | 08:11 PM
  #331
ChoiceCam00's Avatar
Default I Dare You!
I Dare You to cut 16 inches of your stock height F-body! With a 2 inch drop that I have from my sportlines, my car is 49 inches. That would be a 14 inch difference. Oh, I just measured my car from the ground-top of door, 35 inches. From the top of door to top of T-top, 14 inches. Physically you'd have to remove the whole top of the car. Not possible at all! lol
[IMG][/IMG]
Old Nov 29, 2008 | 12:42 AM
  #332
JasonWW's Avatar
Ok
I've already showed were the height can be removed from.
Old Nov 29, 2008 | 02:37 AM
  #333
chaman's Avatar
Was thinking the same thing....
Old Nov 29, 2008 | 04:07 AM
  #334
JasonWW's Avatar
Well, instead of seeing it as the engine tucked under the dash, think of it as the dash and winshield extended over the engine. This makes for a more aerodynamic shape which means better gas mileage and a higher top speed.
See, that's positive.
Old Nov 29, 2008 | 07:13 AM
  #335
crossroads's Avatar
[IMG][/IMG]
it is very much possible........he isnt attempting to create a black hole in his garage...he's just chopping up some metal and thinking outside the box. With the rite tools and research he can get it done
Old Nov 29, 2008 | 09:10 AM
  #336
JasonWW's Avatar
Now that I think about it, 16" doesn't sound right. If stock height is 52" and I'm going down to 38", then I'll be removing 12". So just off the top of my head, about 5" gone from the top and 7" from the bottom.
Old Nov 29, 2008 | 11:45 AM
  #337
VeitSSki8701's Avatar
thing is with my car... if i lowered it a half an inch i would be stuck on the ground and scrapping. The long tubes make the exhaust all low. plus the car sits real low from when i bought it too but I have no idea on how to check if it is lowered.
Old Nov 29, 2008 | 11:49 AM
  #338
another thing is what about the unibody design of the fbody did you factor that in as well
Old Nov 29, 2008 | 02:44 PM
  #339
Default 38 inches!
What is it going to be, 35 inches or 38 inches, make up your mind. Do your homework on specifications.lol
http://autos.msn.com/research/vip/sp...camaro&trimid=-1
Old Nov 29, 2008 | 03:26 PM
  #340
PatriotT/A's Avatar
I'm not a fan of this, but it's your car and good luck.
