What Is The Blackest Of Black Paint?
#64
dupont factory pack black 99k with 4-5 coats of dupont chromapreimer clear and start with 800 on a block and work up to 3000 absolutely the slickest and deepest!!!! HOK is another amazing paint brand!
#65
I know its a mustang but it's an EX girlfriends for a reason!HAHAHAH I sprayed this with a custom HOK candy concentrate and pearl mix with 5 coats of Dupont Chromapremier clear and the pics dont do the color any justice it is deep and glows!!
#66
http://viewmorepics.myspace.com/inde...mageID=9848441
nuttin like a body kit on a domestic!!!! She thought it looked good on there. HAHAHAHAH
#67
Can anyone tell me about the paint Product BASS - 403 i too seeks the darkest / deepest black for my 93 cuttlass supreme convertable. Also does anyone knows any shops to recommend in the chicago, IL area?
#68
I have sprayed them all and black is my favorite. It depends on the quality of the clear used. The blackest black job i ever done was on an old grand national. I took a gallon of sikkens factory pak black, added 2 ounces of candy blue. Now before you freak your paint will not be blue it just kills the browns in the paints which 99%of all blacks has a brown somewhere down the line, even the sikkens. This was sprayed over a black sealer. Now i used the same hardener in the clear in the base only at 10%. We let the base sit overnight to let most solvents escape. Next day came in and wetsanded the base with 1000 to get rid of the peel left behind from the hvlp gun. I then mixed the same base in my SATA 2000 RP hybrid gun and laid the base again. DO NOT sand this stage as the scratches will show here. Next day, Dont worry you wont have an adhesion problem. JUst apply within a 15 hour period. I then applied 2 coats of glasurit high solid clear, With sata 2000 hvlp. baked the paint. I then immediately after the paint cooled started WET sanding again with 1000 and applied 2 final coats of glasurit with my sata RP. I wetsanded with 3000 grit and buffed with a sponge finishing pad and ****, damn darker than the nights sky.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
I've seen a couple ppg with candy blue added and they are black. My truck was just straight ppg black and I parked it next to a cobra with that paint and I kid you not my truck looked like a brown turd...both used same clear.
I can imagine a darker base would look even better but this technique works for off color blacks too.
#73
Beautiful cars!
