Ported heads, drag wheels/tires, nitrous tank
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): AZ
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Ported 243's Sold
A pair of 317 heads that were recently cleaned up and seals replaced by Advanced Induction. These heads have been milled to 71cc (1cc less than stock) to ensure a flat deck. The springs are Crane duals good to .650" lift and have less than 5000 miles on them. These heads are ready to bolton to a FI application and make power. $500 shipped
Jegs drag wheels that will bolt right up to an '04 goat or will need a little clearancing on 05/06 setups due to the larger brakes. Note that the tires are really dry and should not be considered for use. $200 shipped
Last but not least is old reliable, a 10lb nitrous tank with a less than concourse paint job. This bottle has never seen a torch. $125 shipped
just a heads up on the compression on those heads
stock 243 heads on stock ls2 or lq9 is 11.1 compression 25 milled leave you with around 12.5 compression even with bowl work still leaves you at 12.1 compression on stock ls2 that's the math on a stock piston ls1 would net 11.5 compression
that is way INCORRECT information.... 10.9:1 is the compression for ls2/lq9 for ever .006 off its close to 1cc so consider it 4ccs. 64-4= 60.... if you use a stock head gasket 11.475:1 would be the new compression ratio
