RPM C5 Corvette 4L65E with trans brake /Fresh 1000hp Rebuild
Category: Drivetrain
Price: $2900
Part Fits: Corvette
Location (State): PA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
4102181620 call or txt for any info you need
Started as a lvl 6 RPM 4L65 with rossler trans brake, i got the tranny in a car I bought. Trans was just apart for a total freshen up and full build with all the best parts. Trans Was built up by Diablo Formula Racing in ephrata PA (check him out on youtube) with all new clutches, steels, band, sonnax smart drum with billet input shaft and billet 300m out put shaft and the rest of the parts that make it a "lvl 10 Trans" . Has rossler Trans brake and is fully automatic. I just spent over $1500 on upgrade parts alone. Trans is finished and ready to ship trans will be fine for HP in the 1000hp range.
drive shaft shop 1000hp drive shaft (NEW) and torque tube,billet ends that eliminate couplers, 12mm bolt upgrade, OEM flex plate and all hard ware
Crazy cheap prices! Trans gaurenteed perfect! Check my 50+ trader feedback score on LS1Tech under same name !!
**** $2800 shipped for Trans/aftermarket cooler and AN lines to mount cooler in front *****
4102181620
Trans build list
Every piece and part cleaned and inspected
Case was blasted, freshly painted black
RPM 3-4 clutch pack
Sonax smart sunshell
Sonax roller clutch race
Sonax thrust bearing
GM wide 29 element sprag
4L65E low roller clutch
Billet 4th gear servo
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Seal & gasket kit
GM and transtar seals and gaskets
Billet over-run piston
GM 5 pinion planetary gearsets - front and rear
300m Billet output shaft
RPM Billet 2nd gear servo
Sonax smart tech input drum (big fix for 4L60)
Sonax 300M Billet Input shaft
Sonax pump rotor
Sonax Billet Forward Piston
Sonax 2-3 HD Apply Valve
Sonax billet pinless accumulator pistons
Deep Aluminum pan
Rossler Trans brake and button
