Need USED stock clutch,flywheel,slave,master cylinder,shifter
Need good working condition LS1 T56 USED clutch,pressure plate, flywheel, master cylinder, slave cylinder/throwout bearing and stock shifter. I threw all this stuff away when I upgraded but now need it to return a car to stock for trade in. This stuff is basically garbage to most of us so I like to get it as cheap as possible.
Thanks
Thanks
Thanks
Thanks
I'll look and see. Let me know if you are still interested.
Kevin
That be great Kevin, let me know what you have.
The master will have to be bled really good. I replaced it because I was having clutch problems and I thought the master was bad. The new one did the same thing, then I realized I was using a synthetic fluid. I flushed all the synthetic fluid out and everything was fine.
The clutch worked fine for the stock motor, but started slipping when I sprayed the nitrous.
How does 75.00 plus shipping sound?
I can have pics in a little while, my batteries died as soon as I started to snap the picture.
Let me know I can have this shipped out today.
Kevin
