Could deleting TM be worth .2ths in the 1/4?
Moderator
Re: Could deleting TM be worth .2ths in the 1/4?
I think that depends on how much power you are making. With torque management in place, on a very close drag race, where a guy and I were evenly matched, every time my automatic shifted, I could see myself lose ground to the guy beside me.
At each shift, the nose of my car actually nose-dived and came back up at each shift, as if I were granny shifting with a manual stick. Well after removing TM and seeing that my RWTQ was 487, I guess it's not surprising that enough of a timing drop at shift-time to drop 487 RWTQ downwards toward 350 (that's what the stock PCM setting is) would make a huge difference.
After removing TM, at shift time, either it hooks and jummps forward, or it loses traction.. but, it don't nose-dive no mo' As you can imagine, this is tougher on the tranny... but, aren't larege increases in hp and tq hard on drivetrain components anyway?
My car nose dives when it shifts also and it seems like it just KILLS the car when it does it.
Josh S.
Josh S.
I gained 2/10 in the 1/4. It hurts it bad in my opinion. my 2-3 shifts would be KR by 3-4 degrees. I could feel the nose of the car drop on that shift. TM sucks.
