Annoying problem, help
When I started it after the install, it immediately jumps to around a 1,300 rpm idle. It idles really badly until it starts to warm up ... at which time it slowly moves up it's idle to around 2,000 - 2,500 rpms for a minute or two. Then, it will go back down to around 1,200 or so, the back up to 2k, then back, etc etc. Basically acting really irradically. I let it idle for awhile and then drove for around 20 minutes today, to see if it would learn it out, and it doesn't seem to have gotten any better.
I plan on getting it tuned on friday, but until then it is too much of a pain in the *** to drive. I figured it was not going to be the greatest idle, but this is much worse then I had thought. Anyone have any idea what is causing this? Is it just the higher injectors, or could it be that I got some JB Weld in that sensor on the throttle body?
Thanks guys.
cause a bunch of complaints about sealing. I'd
say to do a propane check around all 8 intake
ports as well as around the TB.
I do hear some air coming out of it, which it sounds like it's coming from the back passenger side .... but it's really hard to tell with how loud my engine is.
What do you guys suggest as to how I fix it? It included a gasket, so could I just pick up the intake and reseat it, or should I put gasket maker in there?
Thanks for all the help guys.
Good Luck
Good Luck
And Kevin ... I'll be around your shop for some more tuning soon enough.
Still a waste of my time, but at least they are willing to fix it.
