major fight
What I am doing wrong here? Should I be looking at something in particular since it seems to be a issue with giving it gas? please any help or guidance on what I should look at changing to help tame this crazy car.
Also I am using hptuners.
coming on from a lean condition? If so then you have
something to chase down - why.
If you deleted EGR, take a look at the spark adder
for EGR; is bucking coming with a high advance?
Higher than the main spark table says for RPM and
g/cyl air mass?
GTO will have some differences from your motor
and you might want to spend some time getting a
list together. Different MAF? Different displacement?
Something has to account for suck vs great.
Swaped on my aftermarket maf and it helped alittle. Seems like I am not getting enough air. Def gonna check into the egr thing.
A. Adding advance in those cells
B. Reducing the transition of timing between cells in that area. I had a transition of 4 degrees between 1400 and 1600rpm.
