Random cylinder mis fire and tcc unlock
Old Oct 26, 2008 | 10:01 PM
polarischevy05's Avatar
Exclamation Random cylinder mis fire and tcc unlock
i took my car to the track on saturday amd after 6 or 7 passes my check engine light came on random cylinder misfire was the code then when i left i noticed the torque converter lockup wasn't working i had the predator hooked up so i hit clear codes and it stayed locked for about 5 miles then unlocked again no check engine light but i cleared the codes and continued this every 5 miles on my was home i got home and check the plugs they looked good then i double checked to make sure the wires were on good and went for a drive and the same thing happened it would unlock the tcc and at a steady 3000 rpm you can hear a strong mis. i would like to drive it with out clearing the codes but the trans starts to get warm with out being locked up. any ideas
thanks blake..
Old Oct 27, 2008 | 03:44 PM
any ideas please help
Old Oct 27, 2008 | 04:58 PM
DaveX's Avatar
Stock cam?
Old Oct 27, 2008 | 05:13 PM
edcmat-l1's Avatar
There's a long list of possibilities for a misfire. You need to get it to someone who can diagnose it properly.
Old Oct 27, 2008 | 08:08 PM
ElecTech's Avatar
I'm guessing that 150 shot had something to do with it.
Try a compression or leakdown check.
Old Oct 28, 2008 | 07:44 AM
jimmyblue's Avatar
Moderator
You may have compound problems. Misfires will
inhibit TCC lock. A TCC that won't ever lock,
but gets better at every key-on and then quits
again may be seeing a slip code (P1870?), this
faults into a never-lock mode. But maybe you
are just misfiring full time, like the nitrous ate
a plug tip or something. I'd start with pulling
them and see. And do that leakdown or at
least a cranking compression while the holes
are open.
Old Oct 28, 2008 | 03:37 PM
what should my car have for cranking compression
Old Oct 28, 2008 | 04:34 PM
jimmyblue's Avatar
Moderator
With a stock cam you ought to see over
130# I think; high overlap cams will be a
lot less. Key is more the consistency from
cylinder to cylinder, if one is way less
than the others it's got a problem.
Old Oct 28, 2008 | 06:24 PM
sleepy88's Avatar
crank sensor will cause random cylinder misfire.
Old Oct 29, 2008 | 08:13 AM
jimmyblue's Avatar
Moderator
Actually the crank sensor is used to figure
whether misfire is occurring, a failed crank
relearn or a flaky sensor can drive bogus
misfire detects. I don't think the crank
sensor plays any role in actual misfiring.
But it does, in the counts.
Old Nov 2, 2008 | 10:19 PM
bent pushrod it was wierd it didn't making any valve terrain noise
