04- CTS-V P0300/PO500 codes..help?
Well, this morning I started getting a misfire and then the car started dying on idle...when I limped it home and scaned it I get P0300 misfire code and also P0500 speed sensor codes? Pulled car into garage and now can't get it into R to back it out? What sensor do I need to get to fix this...I guess I was thinking that this was probably fuel related but with no R maybe it is the speed sensor? This is just a simple swap or something? Napa can't find a part number for speed sensor except for the one with the wheel bearing/hub assembly?
Any help?
Any help?
A scan tool will tell you where the missfires are on what cly. If you loose power to one bank for coils, or injectors, and you lost power to the reverse lockout soloniod, So there is a loss of power to things. Check your 15amp ENG fuse. That supplies power to the Reverse lockout.
