service engine soon light flashing...
you'll need to get a tune to disable all of the rear O2 sensor codes... and if you have no more CAT's, you can disable the CAT codes and the COT protection too...
take it to an Autozone if ya have one near ya, they scan codes for free... find out what the codes are, write 'em down, and post 'em up here...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
The codes will likely be a P0300 (random misfire) or P0301-P0308 representing a specific cylinder misfiring.
If it is a specific cylinder, check the plug wires as mentioned, as they may be burning on a header.
If it is a P0300, check the O2 sensor wiring, as well as all of the spark plug wires and plugs as well.
Thanks
Mike
and how did you know / remember he has a predator??!!! he didn't say that??? damn, you're head MUST hurt....
HAHAHAHAHAAA!!!
cool, thx man...
P0300 Random Multiple Cyc Misfire Detected
So is this something that can wait until Jan 2nd to fix or does it need to be fixed immediately? He said it was hard to install the spark plugs and that one is probably just loose?
HAHAHAHAHAAA!!!
Note that it describes a flashing SES as a 'catalyst misfire' detection. So you might want to read about P0420/P0430 as well. You don't mention anything about your cats.
Check all the install stuff you just did. Does the scanner show the car to be lean?
PO300 is a generic misfire code. The ECM has detected that the engine is running maybe a bit rough but cannot determine which cylinder is misfiring. Probably you DON'T have a cylinder miss. The ECM is looking at the reluctor wheel speed in between cylinder firing events, and it measures this in microseconds or millionths of a second. **** happens fast!
Did you install a camshaft? This certainly will set po300, and your cylinder misfire index which is what the ecm looks at when engine is running less than 3000 rpm.
Find someone with an OBD2 scanner and look at the freeze frame when the code was set. This will tell you RPM and engine temp, road speed, engine load, etc. Might help to determine when it sets.
Engine running overly rich or lean?
