Need Help With Turbo Tune (Tune and Log Inside)
Thanks
If the car ran OK on the dyno, and now doesn't, something mechanical has occurred. [Unless you have changed the tune].
Thanks
The car ran out of injector on the dyno. I took the fuel pumps out last night and soldered the 2 pumps wires together and tested them. They BOTH work.
You could get away with 1 bar if you retained the MAF(not SD) and run low boost.
But a 2bar SD tune with a custom operating system will give better control of fuel and timeing in boost.
