E-bay Vats Bypass
Old Jan 2, 2009 | 10:49 AM
wait4me's Avatar
You can jump the purple wires together and just bypass the BCM entirely if you want. The bcm just controls the actual starting solinoid in the vats system. Then sends out a password to the ecm to allow fuel. If you shut off the pcm vats, then it will run as soon as it is cranked.. It is simple to jump the right wires to make it work.. As long as the ecm has been programmed of course...
Old Jan 2, 2009 | 01:37 PM
99corvette's Avatar
Yeah thats what i showed him to do in the picture.
Old Feb 5, 2010 | 01:03 PM
fbodygod's Avatar
i got my 99 trans am tuned by thunder racing and i told guy to tune the passkey out and it still does that damn security light. just got the ebay bypass unit i hope this thing works
Old Feb 5, 2010 | 02:14 PM
99corvette's Avatar
thats because the vats isnt controlled by the PCM, its the BCM.
Old Feb 5, 2010 | 02:26 PM
shoemike's Avatar
Attached Thumbnails E-bay Vats Bypass-2002-f-car-starter-circuit.gif   E-bay Vats Bypass-bcm-fuel-pump.gif
Old Feb 5, 2010 | 02:38 PM
brapril714's Avatar
I bought the ebay one middle of last year, no problems and super easy. It was plug-n-play. Get it and be done with it.
Old Feb 5, 2010 | 02:45 PM
99corvette's Avatar
all i did was take the relay out and put a jumper wire in...its cost me nothing
Old Feb 5, 2010 | 02:56 PM
boola1341's Avatar
Let us know how it goes. I have the same security light problem but the car starts fine. Tired of seeing that security light
 Michael S. Palmer
Old Feb 5, 2010 | 03:03 PM
boola1341's Avatar
Originally Posted by 99corvette
all i did was take the relay out and put a jumper wire in...its cost me nothing.
That took car of the security light coming on?? Was there any other tuning involved when removing the relay and using the jumper wire. My car starts fine....the security light just stays on all the time and is very annoying. Been like that for probably 6-7 months now.
Old Feb 5, 2010 | 03:17 PM
02LS1z's Avatar
i was having the same problem and yesterday my car wouldnt start anymore. I measured the resistance in the key, bought the resisters i needed to match and installed them. after the install the light went out and the car started right up.
Old Feb 12, 2010 | 04:14 PM
vanveldhuizenc's Avatar
What purple wires are you talking about? the ones under the dash panel where people put the resistor? thats the way I would understand that anyways
Old Feb 12, 2010 | 06:35 PM
  #32
99corvette's Avatar
no. the security light will flash while the car is running
Old Feb 12, 2010 | 08:58 PM
  #33
Boosted One's Avatar
I have one of those Vats bypass modules if you need it. Came with my painless harness. I just turned it off with efilive and took the module out. If you want it let me know.
Frank
Old Feb 16, 2010 | 08:18 PM
  #34
So there are four prongs on the relay... how excatly did you jumper wire it? I'm curious because I'm about to try the same thing because I have a no crank condition when my security light comes on. I just want specifics
Old Feb 16, 2010 | 10:01 PM
  #35
99corvette's Avatar
I put spade connectors on each end. broke off one of the tabs on each end. and stuck it down the 2 slots shown. I know its kinda hard to see when ones but you might just have to try different ones till it cranks.
Old Feb 17, 2010 | 07:26 PM
  #36
so all four terminals are connected to that wire?
Old Feb 17, 2010 | 09:31 PM
  #37
99corvette's Avatar
no just 2. ill check when i get home and see which 2.
Old Feb 18, 2010 | 07:49 PM
  #38
ok cool! thanks a bunch!
Old Feb 18, 2010 | 11:13 PM
  #39
awd-rwd racer's Avatar
i bought one and it didnt work. the little blue light turned on but the car wouldnt start.
Old Feb 18, 2010 | 11:59 PM
  #40
99corvette's Avatar
try what i did and see if that works for you. wont cost you anything if you have about 2 inches of wire and some connectors.
