E-bay Vats Bypass
Old Feb 22, 2010 | 06:42 PM
  #41
Blk_Ws6's Avatar
Originally Posted by 99corvette
try what i did and see if that works for you. wont cost you anything if you have about 2 inches of wire and some connectors.
So what you did to the relay that got your car started or just got rid of the security light?
Old Feb 22, 2010 | 06:58 PM
  #42
99corvette's Avatar
took the starter relay out and put a jumper wire in so the circuit is always complete. It should crank but the security light will flash while the car is running though
Old Feb 23, 2010 | 08:22 AM
  #43
Blk_Ws6's Avatar
Which wires did you jam it up with?
Old Feb 23, 2010 | 04:56 PM
  #44
99corvette's Avatar
Sorry for the delay guys...
Old Feb 24, 2010 | 01:07 PM
  #45
vanveldhuizenc's Avatar
Awesome! I'm definitly gonna try that! the lights on the dash thing doesn't bother me but the whole not even starting thing does
Old Feb 24, 2010 | 03:49 PM
  #46
99corvette's Avatar
Yep same here
Old Feb 24, 2010 | 06:30 PM
  #47
Blk_Ws6's Avatar
So by doing this it eliminated the security issue?
Old Feb 24, 2010 | 06:34 PM
  #48
Blk_Ws6's Avatar
I think its my starter, my security light goes off after the ignition is on but when I turn it all the way to start position it does nothing what could this be fellas?
By the way my starter was dragging before ,just never heard of it not doing nothing when trying to start.
Old Feb 24, 2010 | 07:03 PM
  #49
99corvette's Avatar
before when i tryed to start minr the security would come on or flash i cant remember and it would do nothing. But once I did thid mod it cranks every time now.
Old Feb 24, 2010 | 07:48 PM
  #50
Blk_Ws6's Avatar
Jump the wire in the relay?
Old Feb 25, 2010 | 12:09 AM
  #51
99corvette's Avatar
Yes take the starter relay out and put a jumper wire in and see id it cranks. The security light tells the BCM not to engage the relay. So if your starter isnt doing anything thats most likely the reason. If not it may be a bad starter.
Old Apr 12, 2010 | 07:37 PM
  #52
Formula/LS1's Avatar
I put a jumper wire in and and it worked intermittently too. I ended up buying the vats bi-pass system from Baker Electronics for $24.99. Very simple install. Installed today so I'll keep this thread updated on the results.
Old Apr 18, 2010 | 08:04 AM
  #53
So far, so good ! My car has been starting every time with no problems. Seems to me the Baker Electronics vats bypass worked.
Old Apr 18, 2010 | 08:15 AM
  #54
fbodygod's Avatar
it is complete crap just unplug the it unber the dash and stick the proper resistor in there takes like .10 and 5 min no more problems
Old Apr 19, 2010 | 12:10 PM
  #55
Dummybait's Avatar
dumb question... whats VATS?
Old Apr 19, 2010 | 05:29 PM
  #56
Vehicle Anti Theft System
Old Jun 18, 2010 | 11:04 PM
  #57
koolrayz's Avatar
THanks for sharing. I will try this tomorrow
Old Jun 18, 2010 | 11:35 PM
  #58
99corvette's Avatar
It has worked for me, cranked every time. As long as you dont mind the security light blinking
Old Jun 19, 2010 | 12:08 AM
  #59
chaman's Avatar
Can the security light be unplugged, taken out so you don't see it anymore?
Old Jun 19, 2010 | 11:10 AM
  #60
99corvette's Avatar
You can take the gauge cluster out and then take the bulb out
