E-bay Vats Bypass
Old Jun 19, 2010 | 05:08 PM
  #61
chaman's Avatar
Exactly.
Old Oct 14, 2010 | 08:59 PM
  #62
fheckro's Avatar
Question:
when i turn the key to "run" position all the interior stuff works but I don't see any check engine or anti theft lights or stuff like that. then when i turn it to start everything dies. Is that the VATS messin with me or do i have another problem??
Fred
Old Oct 15, 2010 | 08:48 PM
  #63
rickou812's Avatar
Dead battery or bad battery connection...
Old Jan 31, 2012 | 09:31 PM
  #64
meanandclean2000's Avatar
hey guys kind of on topic/ off topic... I have a 2000 Z28 that from time to time wont turn over, everything else works normal but wont start, lights on dash all act as normal, headlights shut off when turned to start position as they normally should but starter does nothing, security light on for 3 seconds then turns off as normal but heres the kicker.....I can jerk on the steering wheel and it will start... anyone else ever delt with that senario
Old Jan 31, 2012 | 10:14 PM
  #65
ucanthangwme's Avatar
SandmanWs7 has a really good, detailed write up on bypassing the VATS.
It's not on this site(not that I know of), but it should be easily found with a google search for "How to bypass your VATS". If you need anything more specific for a search- ls1.
Old Feb 1, 2012 | 12:18 AM
  #66
99corvette's Avatar
Trying another key. If you don't have one try getting one made. Sounds like you got a broke wire though. I would pull the cover off the column and look
