98 to 02 pcm conversion
Pinout: http://www.ls2.com/boggs/torques/98pinpcm.htm
Swap guide: http://www.chipsbyal.com/convert98/
Once you swap the pins, you will have to swap the fuel segment from the 0411 Express Van to your file. If you use EFILive, I can send you my tune (OS 12212156, from 02 F-body) with the segment swapped and parameters corrected for the 98 tank. If you use HPTuners, you'll have to find a way of doing this.
As far as I know if you want to continue to use HPT, then you will need to swap the cluster and sending unit in the tank. The new cluster only uses 17 wires as opposed to the original 35 on the 98. I know, not more wiring!
Hopefully, I am not up to date with HPT and they have added this capability.
You just need to read the file made with EFI with HPT to get the data in the the format that HPT wants, or somebody with hpt could make the file work if they have an unlimited tuning for that year/make.model, and load in a binary file.
That shop called me and asked why I "locked" the tune. I don't lock any tune- period. Come to find out they were using HPT- they could not talk to it. They changed the OS but, then his fuel gage didn't work, which led to a cluster swap.
Maybe somebody could read it some how?
Maybe ED from (Horsepower factory) could chime in? Jesse B?
Ryan
With that said the tuner will probably get a vin/os pair error if the vin in the pcm doesn't match what operating systems GM offered which is the standard we go by. This check is there for many reasons and cannot be removed as it is used to keep the integrity of our Year/Model licensing.
So if you plan to install a 99 pcm into your 98 you would need to have the 99 vin still in the pcm to do so.
-Bill
