02 Sensor low voltage error
Can someone tell me what is wrong? Thanks. I find it hard to believe both 02 sensors have gone bad. Could it be something else. How can I find out?
any sign of activity. Read heater power too. The
heater ought to have 12V wire-wire (may use a
couple of sewing needles to probe into the conn.)
and the O2 ought to be bouncing. But a gross
and untrimmed lean error could produce a stuck-
low output as would too-cold sensor (heater fault
or just the long tubes).
I don't recall if my scanner will show heater voltage, I think it just shows if the heater "passes" diagnostics.
This stuff is tough to trouble shoot, especially over the internet. Jimmy knows way more about this stuff than I do, but what he's saying is a much more succinct version of what I wrote you in a PM just now.
BTW, don't forget to check your grounds on the back of the head!
If you can't find the problem, it might be time to give a new set of sensors a shot....
