Cam sensor prob
Old Feb 24, 2009 | 09:18 AM
TTOP350's Avatar
Default Cam sensor prob
Ok, Im stumped, I have a 02 ZO6 that is not seeing a camsensor signal.
It does the long crank, swap firing order 180deg burble thing, swaps firing order back and then will run
Things we have done.
checked all 3 wires for contiunity (ok)
changed and reprogramed PCM
Preformed a crank relearn..
Also 4 giggles change crank sensor and checkd those wires also..
chaged cam sensor 3 times. new and direct takeouts from runnning cars.
Is it possible the cam is broken right in front of the camshaft reluctor?
Going out to shop to check cam now i guess..
Old Feb 24, 2009 | 09:54 AM
Frost's Avatar
I've seen the cam bolts back out and cause this...
Old Feb 24, 2009 | 10:22 AM
edcmat-l1's Avatar
Female pins in the connector.
Old Feb 24, 2009 | 10:24 AM
Frost's Avatar
they are metripack 150 female sealed terminals
Old Feb 24, 2009 | 11:17 AM
TTOP350's Avatar
Thanks for the fast replys. Cam is not broke.
Ill check cam endplay and tighten up female terminals.
Old Feb 24, 2009 | 05:13 PM
TTOP350's Avatar
Cam endplay is ok. The reluctor seems to stay centered in the cam sensor hole.
I tightened the female sides of the conector..
still the same probs...
Old Mar 15, 2009 | 12:09 PM
GTA91's Avatar
Tony, I'm having similar issues with my new 402 LS2 right now... might call you in a minute or 2.
Old Mar 17, 2009 | 04:41 PM
TTOP350's Avatar
Anyone else have any ideas???
Old Mar 17, 2009 | 05:19 PM
rao's Avatar
rao
Do you have the right cam gear?
https://ls1tech.com/forums/conversio...e-ls1-ecm.html
Old Mar 17, 2009 | 10:04 PM
GTA91's Avatar
I fixed mine, it was throwing a PO343 and wouldn't start sometimes... started hard at other times. Ended up being the 2 outer wires needed swapped on my LS2 cam sensor extension harness from Casper Electronics. Swapped them and all is well!
Old Apr 8, 2009 | 01:07 AM
CamaroSS22's Avatar
I had the same cam sensor problem on my ls7 swap. I chased my tail for hours over that one.
Old Apr 8, 2009 | 08:11 AM
GTA91's Avatar
Yeah it sucked... it left me stranded on one of my first trips in my new 402ci LS2 build... I stopped and shut the car off to do some tuning and then my laptop died, car wouldn't start, couldn't scan it without a laptop, and drained the battery trying to get it started. LOL I was only about a mile from my house... ended up having the wife tow me home with our Dmax.
Old Apr 8, 2009 | 08:48 AM
Pewter_LS1's Avatar
had this exact same issue with my TA changed the battery and it was good to go...had something to do with the low volts... how did you fix your issue?
Old Apr 8, 2009 | 11:57 AM
GTA91's Avatar
Read post #10 for how I fixed my issue...
Old May 19, 2009 | 12:15 AM
MY99TAWS6's Avatar
Going thru this now on my 99 ta. I had intermittent after doing engine swap last year. I put in new cam sensor for something to do this spring and not the problem is full time. Trying to tune with new injectors and they are not working and now figured out its likely from this problem making the car go to batch fire.
I dont want to take my intake off again but guess have no choice if its not something ecu or harness I can get to.
