Lap top computer stand for our cars?
Old 10-07-2004, 12:07 AM
  #61
Ed Blown Vert's Avatar
Isn't the bolts that hold down the seat under that hard plastic?
Old 10-07-2004, 01:48 PM
  #62
Midnight F-117A's Avatar
Originally Posted by Brody
Remove the bolt or plastic clip (hard to tell which) holding the plastic cover in, the one that's a 90 degree looking and touches the carpet and see if there is a bolt under there parallel to the floor. If there is, then get the same size bolt but 1/4" to 1/2" longer and use that to mount the base mounting plate.
And you either may ditch the plastic piece when installing the stand, or modify it to fit as possible.
Old 10-07-2004, 01:53 PM
  #63
Brody's Avatar
Parts are on the way soon! Thanks guys!
Old 01-08-2005, 04:39 PM
  #64
Update?
Old 01-08-2005, 10:15 PM
  #65
Brody's Avatar
Posted them long ago on Z06vette.com
PM me your e-mail and I'll send them.
Old 01-09-2005, 10:11 AM
  #66
shep28's Avatar
Originally Posted by NCal
I made my own Laptop Stand from some aluminum stock that I liberated from the scrap pile at work. The Laptop surface is 17"x15"x1/8" thick aluminum and the mounting posts are black Anodized Aluminum ~1.25" round that were once used to stabilize crated machinery during shipping.
I drilled & tapped the post ends so they screw onto the threads where the passenger seat mounts, then drilled the plate accordingly. I also traced around the laptop and placed some shelf holders (that I had) around it's periphery to keep it from sliding, then covered the surface with ribbed rubber matting. The whole thing took around 2 hours to make and can be mounted and/or disassembled in under 2 minutes.
So far the laptop has stayed in place well during hard acceleration and twisty roads (even with the roof panels removed), but I may run a strip of velcro across the 'puter near the screen for insurance later on. I store the box for my HPTuner cable under the stand (on the seat). It stays out of site and also eliminates any "bounce" when driving over uneven surfaces (driveways, speedbumps, etc..). Oh yeah, total cost came to about $16 bucks.
You can see more pictures @ http://img78.photobucket.com/albums/...Laptop%20Stand .
Nick
How much would you charge to make me one of those?
edukatek12@aol.com
Old 01-10-2005, 07:57 PM
  #67
Dragman's Avatar
I just put a Jotto laptop stand in my C5 and it worked out nice!
