maf ????
one I heavily ported. The PCM should filter the
MAF input to produce a lot less jumpy airflow
and you want to be looking at the Dynamic
Airflow number, for low end tuning, which is the
thing that is used for fueling. The MAF Hz / airflow
should be a lot more stable at higher flows.
MAF would prefer to be in straight pipe and far
from the impeller as possible (if not on the inlet
side, though much blower-TB volume could add
some peculiar lag effects in that case).
