new cam throwing misfire code
anyway, im getting crazy misfires during idle, but none during higher rpm.
is that easily fixed with a tune?
thanks,
Jeremy
thanks,
Jeremy
Definatly fixable! I'm still learning my HP Tuners software, but I'm about to wake my car back up with a shot and get a wideband in the car...so I'm hoping i can continue to learn a little bit more then.
The code can either be deleted, or by simply tuning the car the computer wont throw the code. If you plan on modding more than BPU, go grab a copy of HP Tuners Pro, it will come in handy trust me! Like now, if you had HP tuners, you could send me a copy of your tune and I might could tell you how make your car a little more driveable
car is running good and strong. my father n law is a gm mechanic. put his scan tool on and checked the code. i think it was PO300, for misfire. so we watched the misfires as they were happening. they were only happening at idle, which is about 750-800rpm.
i have no idea what the misfire threshold is. is it a set amount of misfires that the pcm deems abnormal?
thanks,
Jeremy
oops, missed your post. how much would that cost me?
ive thought about getting into tuning, but its way too expensive for what im going to need. im done with mods on this car. its my new daily driver and im leaving it alone now.
thanks,
Jeremy
You need a bigger cam
HP Tuners is $600 i believe, or $750 for the Pro version. The proversion can accept inputs from external sensors, like a wideband or EGT.
Also, if you go to get your car tuned from a shop who uses HP Tuners, they may charge you a "fee" to unlock your computer + Tuning. Although you only have to unlock it once, i instantly saved money the first time i got it tuned, of course i also had to drop off my laptop with my tuner since the unlock was tied into the laptop with my HP Tuners software.
im not sure why you have the two smile guys dueling. and im not sure how you got that from my post.
when i put the cam in my camaro, i didnt have any type of SES codes, even before the tune. i just want to know if this is common on an LS motor. if so, i wanted to know how it was being fixed (even though i dont know a whole lot about PCM tuning).
as for a bigger cam, i still have to pass CA smog.
thanks,
Jeremy
