need help ASAP
Old Mar 18, 2009 | 02:30 PM
WS6Power's Avatar
Default need help ASAP
I`m in the middle or an intake swap on an 01 Pontiac TA. It looks like I broke the oil sending unit and I don`t have time to replace it. How will the car run without it? It`s a single wire unit, so will it throw a code??? It doesnt look like it will leak oil or anything. Thanks!
Old Mar 18, 2009 | 02:36 PM
2001NBMZ28's Avatar
Get a new one and replace it before reinstalling the intake - it's a PITA to get to.
Old Mar 18, 2009 | 02:57 PM
WS6Power's Avatar
ttttt
Old Mar 18, 2009 | 06:17 PM
WS6Power's Avatar
Is anyone out there running without a oil pressure sending unit? Does it throw a code??? Thanks!
Old Mar 18, 2009 | 10:06 PM
SS SLP2's Avatar
I have never tryed to run with it broken, it is not hard to install with the intake in place if you buy the specal socket to fit the sending unit, sockrt only about 8-10.00
Johnny
Old Mar 18, 2009 | 10:07 PM
poolshark021's Avatar
You can't leave the broken one in there, it will leak oil as soon as you start it up. Ask me how I know
Old Mar 18, 2009 | 10:32 PM
WS6Power's Avatar
ttttt
Old Mar 20, 2009 | 05:19 PM
WS6Power's Avatar
Well I got my car back together with no issues and she runs great. I found out that you can run a 99 and newer LS1 without the oil pressure sending unit. No leaks and no codes! Also about 5 years ago I pulled the oil catch can and installed a metco valve cover breather and the intake was very clean, not a drop of oil. Time to hit the track!!!
Old Mar 20, 2009 | 05:53 PM
edwardzracing's Avatar
Lucky indeed... and ballsy not knowing what your oil pressure is.
Old Mar 20, 2009 | 07:09 PM
2001NBMZ28's Avatar
What does your gauge read now? Don't understand why you just didn't install one before resinstalling the intake?
Old Mar 20, 2009 | 07:40 PM
WS6Power's Avatar
Well my low oil light still works and with a LS1 thats all you need. LOL The gauge now "shows" 80 psi. I had to have my car back and nobody had the unit or special tool in stock. Hey "2001nbmz28" you live in Jax too?! I just moved to Jax and will be running at Gainesville on 4-8-09. I`m stoked, I heard that Gainesville is the fastest track in the country!
Old Mar 21, 2009 | 11:25 AM
Frost's Avatar
Well my low oil light still works and with a LS1 thats all you need.....
You can't really be serious...
Old Mar 21, 2009 | 11:28 AM
SS4Luck's Avatar
i really think he is...
that was really about one of the stupid possible things to do in that situation. you havent had your car long huh?
Old Mar 21, 2009 | 10:52 PM
Doc's Avatar
Doc
To the OP, we are in Jacksonville. We can help you out. You really need to know what kind of oil pressure your LSx powered vehicle has at all times. This can be a very unforgiving thing.
