Can ANYBODY figure this OUT!
Old Mar 19, 2009 | 01:15 PM
SD99TA214's Avatar
Default Can ANYBODY figure this OUT!
OK TONS of threads on hooking up wide bands DIRECTLY to the egr to log afr with hptuners.
BUT i need to know how to wire the Innovate MODULE to the egr for this.
if you dont know what im talking about, i bought the lc-1 innovate wideband and the wind band plugs into a module and it has 2 stereo outputs (i know those dont go to the egr) there are 6 striped wires coming of the module through a small harness as listed through the manual
red=12v
blue=ground
white=ground
yellow=analog output 1
brown=analog output 2
black=calibration (momentary switch)
now i have searched every thread on this to my knowladge and cant find this info. but how do i wire this up to log afr through HPTUNERS. the rest i can figure out, its the wiring i cant.
ANYONE?
Old Mar 19, 2009 | 02:17 PM
SD99TA214's Avatar
[sound of crickets]
Old Mar 19, 2009 | 02:54 PM
2002_Z28_Six_Speed's Avatar
you need to hook one of the analogs to whatever pin is associated with the voltage of the EGR then you will have to hook the LC1 up to a computer and program the LC1 output to the correct parameters.
never had EGR sorry.
what is the pin out and descriptions of the egr harness?
Old Mar 19, 2009 | 05:22 PM
SD99TA214's Avatar
I dont know. ill try to figure it out, but im almost positive the wire i need on the egr that is the "signal" wire is the brown one on the egr harness. so basicly ill hook it up as follows?
red= 12v ign on
blue=ground
white=ground
yellow= to brown on the egr (if that the correct wire)
brown= nothing
black=calibration, (momentart switch)
but my understanding is the the analogs are for OUTPUT, like gauges or screens? not for sensor input.
i think it might be the white or blue that goes to the egr but dont know for sure.
Old Mar 19, 2009 | 05:29 PM
SD99TA214's Avatar
ok just called innovate and they said that the yellow and the brown off the wideband module ARE the signal outputs so you were right................
im assuming now i would hook the yellow wire to the brown on the egr and that will get me the signal info im looking for?
Old Mar 19, 2009 | 06:19 PM
Zzzzz's Avatar
If I recall the wire you want is gray, number four if you count from left to right on the connector.
Old Mar 19, 2009 | 07:04 PM
SD99TA214's Avatar
Originally Posted by 405HP_Z06
1999+ LS1 PCM EGR Pin-Out:
Blue Connector:
Pin 41 - Black, EGR Pintle Position Ground
Pin 47 - Grey, EGR Pintle Position Sensor 5V Reference
Pin 55 - Brown, EGR Pintle Position Sensor Signal
Originally Posted by DirtyJohn
I send my Wide band 5v signal INTO the EGR brown (as do alot of folks), if that helps.
Does this help?
Old Mar 19, 2009 | 07:47 PM
Zzzzz's Avatar
Come to think of it, that sounds right...
Glad I could be of assistance!
Old Mar 20, 2009 | 12:40 AM
SD99TA214's Avatar
well tryd this
yellow=brown
created custom pid..
even enabled egr,
NOTHING.
Old Mar 20, 2009 | 03:39 AM
SD99TA214's Avatar
GOT IT.
Goes as follows
Innovate lc1 module =destination
red=12v ign on
white=common chassis ground (ccg)
blue=(ccg)
yellow= nothing
brown=brown on egr harness
black=momentary
Old Mar 21, 2009 | 01:39 AM
shoemike's Avatar
Connecting wideband via EGR or A/C Pressure in HP Tuners
post #5
