Olfa afr
Old Apr 3, 2009 | 06:51 PM
SuperC1's Avatar
Default Olfa afr
I know someone else besides me has had this problem, but I can't seem to get any clear answers on this. Here's the situation;
I have placed all my OLFA tables to 1.00 above 158 deg, but for some reason at idle I am still seeing 12.2 to 13.1 commanded AFR. I've checked my tune several times, but there must be something I'm missing. What else could be left? PE enable is stock except I moved the enable rpm down to 4500. I am in OLSD 2bar by the way, with the maf disabled.
Any help would be appreciated.
Old Apr 3, 2009 | 06:55 PM
Frost's Avatar
post the tune... log would be nice too, but post the tune.
Old Apr 3, 2009 | 07:14 PM
JonCR96Z's Avatar
Have you tuned the VE table?
Old Apr 3, 2009 | 09:36 PM
SuperC1's Avatar
The ve table looks great, the AFR looks good on the wideband, but its the commanded AFR thats bugging me. It would be nice if I could have those two to match.
Old Apr 3, 2009 | 09:44 PM
foff667's Avatar
LS1TECH Sponsor
Without a tune & scan its impossible to help.
Old Apr 3, 2009 | 11:55 PM
SuperC1's Avatar
Copy of tune and log attached, take a look. For some odd reason the tps does not show up on the chart but it works fine on the table.
File Type: hpt
File Type: hpl
Old Apr 4, 2009 | 12:44 AM
Frost's Avatar
Here give this a try.... Your PE enable from 1200 and down was 0% throttle. Down in that area with it being richer than your OLFA, it's value is used. When you come out of the rev, you are above 1200 and under 64% TPS, so it moves back to referencing the OLFA which is 1.0. That is the explanation for the behavior in the log.
Old Apr 4, 2009 | 12:46 AM
JonCR96Z's Avatar
Your PE tables are enabled at 0% throttle from 0-1200 rpm. So you're commanding 1.105-1.109 enrichment.
JonCR96Z's Avatar
Here give this a try.... Your PE enable from 1200 and down was 0% throttle. Down in that area with it being richer than your OLFA, it's value is used. WHen you come out of the rev, you are above 1200 and under 64% TPS, so it moves back to referencing the OLFA which is 1.0
Beat me to it
Old Apr 4, 2009 | 12:49 AM
Frost's Avatar
Just trying to help; glad others are too.
Old Apr 4, 2009 | 12:20 PM
SuperC1's Avatar
Thanks guys, any reason why the tps doesn't show up in the graph?
Old Apr 4, 2009 | 12:22 PM
SuperC1's Avatar
That's rite I forgot I did that a while back when it was n/a..
Old Apr 4, 2009 | 08:18 PM
JonCR96Z's Avatar
It is showing up. You're just logging TPS voltage instead of %.
Old Apr 4, 2009 | 09:04 PM
SuperC1's Avatar
Ok, thanks guys...
Old Apr 8, 2009 | 09:37 PM
SuperC1's Avatar
It was set for %, went back and set it up again, but still no joy.
Old Apr 8, 2009 | 09:42 PM
Frost's Avatar
post your .cfg file that you are scanning with.
Old Apr 8, 2009 | 09:43 PM
JonCR96Z's Avatar
This is what I'm seeing:
The third PID from the top left is Throttle Position measured in volts. Is that not what you have? If not post the config.
Old Apr 8, 2009 | 09:46 PM
SuperC1's Avatar
Went out and made a test run today and the car is breaking up badly above 5k. I'm wondering if this is a fuel issue or spark issue. Log file is attached.
File Type: hpl
Old Apr 8, 2009 | 09:48 PM
SuperC1's Avatar
Thats in the table, I'm talking about TPS in the graph.
Old Apr 8, 2009 | 09:53 PM
JonCR96Z's Avatar
You have to log it here for it to work in there and right now the graph is for ETC%. Change both to Throttle Position % and it'll work fine.
If your wideband is accurate at all I'm surprised you even made it home, lol. It's a touch on the lean side. 19:1 should be more like 12:1.
