Need help, again
Old Apr 7, 2009 | 04:15 PM
Justin Gibbons's Avatar
Default Need help, again
My car is missing, kinda like its being held back or something....engine is very rough as it revs...seems that the problem is with cylinder 4...switched, coils, injectors...still have the problem...could this be the computer?
secondly, do Ls1's fire each cylinder individually, or each bank, or i don't know...
...so frustrated!!!
Also, can i use a computer from another year f-body to see if the comptuer is the problem?,
guy at the local part shop said a 99 silverado computer might usiable, that doesn't seem right to me
Old Apr 7, 2009 | 07:50 PM
anyone have anything for me/
Old Apr 7, 2009 | 11:39 PM
Here are the plugs from the passenger side, they were all installed at the same time...the one thats still white is cylinder 4;
Any ideas why this is happining?
Attached Thumbnails Need help, again-plugs-002.jpg   Need help, again-plugs-005.jpg   Need help, again-plugs-001.jpg   Need help, again-plugs-003.jpg   Need help, again-plugs-004.jpg
Old Apr 8, 2009 | 12:05 AM
98Aggie's Avatar
Moderator
Is the plug wet or dry when you removed it? Can't tell by the picture.
Old Apr 8, 2009 | 05:55 AM
its dry
Old Apr 8, 2009 | 06:41 AM
moehorsepower's Avatar
Obviously it looks like it is not getting much fuel, First swap the injector out to another cylinder then check it again, If that plug now shows the same signs then either you have a faulty injector or a wiring issue on that bank...
Old Apr 8, 2009 | 10:16 AM
changed out the injector...still have the same problem,,could this be due to a head gasket leak, or problem with the bank.
Old Apr 8, 2009 | 08:17 PM
98Aggie's Avatar
Moderator
Listen to the injector to see if it is firing, doubt it is since the problem stays with that cylinder. More than likely you have a wiring problem (Lt Blue/Blk wire running to the computer)
Old Apr 8, 2009 | 09:08 PM
joecar's Avatar
See if you get these 2 signals for that cylinder:
- injector (fires the injector)
- coil primary (saturates/fires the coil)
Use a DMM or a test light or whatever... it should indicate a pulsing signal while cranking/running.
If you're missing either of those, work backwards along the wiring, see if there is continuity all the way back to the PCM connector.
