Just bought ATAP...How to output files to EXcel??
This sucker did not come with any instructions. I have been told that you can link the program to excel to creat output files in Tabular form. Anyone know how?
TIA,
-Nick
TIA,
-Nick
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
First you need to setup or "configure" the parameters you want to log. Then when you log a run it will ask you to name and save the run. It will be saved as a Atap file. When finished, you need to go back into ATap and convert it to a ".csv" or comma separated value file (look in the drop down menu). Then you can open it in Excel and convert it to a standard Excel file.
This is how I do it. If there is a quicker, less involved method I would definitely like to see it detailed.
I use the spreadsheets from http://smiley.tzo.com/fbody/atap/atap.htm and just 'import external data' within excel itself instead of converting it to a csv first. FWIW.
