Performa trans Yank stall. My tune, efi live
alright so I put a performa lvl 2 trans and a yank pt4000 stall in the car. I got efi live up and going and I got the tune off the car. Its not a stock tune. I think performa wants the line pressure tables set back to stock so I suppose thats a starting point.
attaching my tune.
attaching my tune.
So. do you have a question? Are you wanting to know how to tune for the transmission and for the stall? Your current post contains only statements, no questions. Not trying to be a smartass, but it is difficult to discern with such a post.
Let us know, it would really help.
oh how silly of me. But yeah, im trying to learn how to tune this thing. Im not too sure on how much needs to be changed yet. Id like to get input and keep posting up revised tunes. or something like that.
so, line pressure to stock?
should i make the lockup only engage in 4th? im guessing to do that I would max out the third gear apply speeds.
and just any useful information about anything I should be changing for this stall would be appreciated.
-So trans pressure is back to stock.
-torque reduction is zero'd out.
-TCC third gear lock up was maxed out. Now what should i do with the 4th gear? I think stock locks up at 36mph. whats a good lockup speed for 4th?
-TCC throttle release. The values are all at 100. the same as stock. Should this be changed any?
-shift times all at zero.
-throttle kick down? should this be changed any?
I scanned the car but im not getting any codes yet. Are there any that I should just disable from the get go?
revised tune attached.
The TCC duty cycle tables should be set for 100 max and 99 min.
And I've had a P0757 code, I've also read that some will get a P0751. So you can turn those off. Otherwise you might be riding around without a few gears til you get the code turned off.
i dont even have a po757 code in my 98 pcm. im not throwing any codes either. Is it possible to go in limp mode without pulling a code?
and what about tuning the part throttle shifts? i bumped all the tables up one to make it shift just a tad later based on some advice on the efi live forums. is that all I should do?
Im having some trouble. I have a log of today. Started the car. Let the idle calm down. Ran it through some gears. Backed out of the driveway, got about 10 feet and the car stalled out. Started it back up and put it in drive. took it for a half spirited drive around the block and came back. hit about 5k rpm for a second at one point. the car felt slow. But that could be not having a cam for this stall yet. It didnt seem to pull at a steady pace. I got back to the driveway and ran it through some more gears. At one point I put it into drive and tried to move forward but the car didnt move. Took it to 3k. Dropped it down to manual 1st and it went forward. Sometimes when I put it in drive I swear I hear a faint grinding noise.
Some things I noticed from the log. The transmission switch says invalid when the car acts up. It will say its 3rd gear but I dont think its going into any gear. And im not pulling any codes. Im not sure if this is just all tuning or if something is actually wrong.
heres my current tune and a log file.
I'm not familiar with efi live, but in HPtuners, you typically do not set your shift speeds to 0. I have mine set to ".100". Supposedly if it is set too low, the tranny gets confused or something, but I have not tried it, it is just what I have heard happens. Might give that a try? Good luck.
Also, change your sig, you are probably jinxin yourself saying your tranny and converter are waiting to go in. Its bad ju ju to do that you know. lol.
ha, once they work!
i just went and let the car idle. perfectly fine. Put the car in reverse and the rpm's drop and the car struggles to not die for a second. I hear a bunch of dull thumping noises. Put the car in neutral. Back to normal idle. Put the car in drive, back to the bad idle and noise. Shift down through all the gears and go back up. Put it back in park and it starts sounding like a bunch of rocks flying around inside the transmission. sigh. guess ill have to get under there when i get a chance. something is bad.
LS1Tech Sponsor
The code you are looking for is PO756 on your car. later ones used po757
The idle issues are comon and can take a little effort to work out.
I PM you the name of someone who will likley be able to advise you on all of these. He does tuning for a living.
Frank
Frank
__________________
