Timing question - need to figure this out before I spray a 125 shot
OK, using my predator data logger, I am trying to get my timing correct before I hit my 125 shot. The data does not compute for me though. Please give me some help on this.
Stock car reading - WOT
rpm Timing Retard
4200 16.5 2.9
5100 19.5 2.5
5800 22.5 2.3
Predator canned tune
rpm Timing Retard
4200 25.5 0
5100 25 0
5800 25.5 0
Predator canned tune - retarded timing over 4,000 rpm by 4 degrees
rpm Timing Retard
4200 rpm 21.5 1
5100 rpm 19.5 2.5
5800 rpm 20.5 2.3
What gives? how the heck can I get timing retard on the stock tune and when I pull 4 degrees out of the predator tune? Running the canned predator tune the #s are perfect, but I am thinking that is too much timing for a 150 shot.
My fuel pressure reads about 56 psi for all three scenerios, seems solid. My A/F is also very close with each, about 13.3:1.
Any help is appreciated. If I were not spraying, I would leave the predator canned tune, but I am worried about the 25.5 degrees of timing?
rpm Timing Retard
4200 16.5 2.9
5100 19.5 2.5
5800 22.5 2.3
rpm Timing Retard
4200 25.5 0
5100 25 0
5800 25.5 0
rpm Timing Retard
4200 rpm 21.5 1
5100 rpm 19.5 2.5
5800 rpm 20.5 2.3
No, I have a dynotune A/F ratio gauge - It is the most acurrate gauge on the market, but I know it is still not a wideband. It reads a pretty constant .89 which equates to a 13.3:1 on a wideband.
