just got done with my 'full bolt ons' now car dies
The 13111s will work for LTs? They will reach the first set of o2 plugs? Since i dont have any cats and i have a dumped exhaust, i have heard that o2 sensors go out about once a year, which doesn't seem too bad. I can deal with that. I work at autozone and we carry the bosch o2s, not the delcos, so i can get discounts on those, which is of course why i would get those.
As far as the O2s being your problem just disable closed loop. Either in the tune or with the bidirectional controls in the scanner. It your problem goes away then more than likely the O2s are the problem.
If you look at these logs and notice that the histograms look screwed up, it is because the MAF is being logged and the histos are using them for their dynamic airflow measurement. That's a problem with no MAF.
UnZFeat'd - Leave the dynamic cylinder air in the table view of your scanner, but remove Mass Air Flow (SAE) and the histograms will populate correctly. They are not usable (to copy paste into the editing file) like this. To answer your question, SD is speed density. How does the car feel?
Also, your largest LTFT is less than 5%, so the MAF was definitely the problem.
It's time to tune for those boltons, it's rich and has stock timing at WOT.
t has tock timing right now because i plan to run nitrous in it. Right now it is jetted for a 75 shot, but i plan to go up to a 150 shot if the tune will help me do it. It felt a lot better without the MAF. There was no hesitation at all, and it didn't want to die on idle.
