Quick question
Old Apr 19, 2009 | 05:58 PM
the_merv's Avatar
Veteran: Air Force
Default Quick question
I have a friend that has EFI Live and for some reason the Scanner that you plug the Lap Top into and you plug the OBDII Cable into doesn't want to communicate with it.
Can you get a cable to go from the PCM to the OBDII Connector without having to go into that Scanner..or does it have to go into the Scanner first?
Also I'm looking to get HP Tuners if anyone has one they want to part with.
Thanks.
Old Apr 19, 2009 | 09:14 PM
bills98ta's Avatar
Has to go though the scanner. Check your cigarette lighter fuse. Same power circuit for the OBDII connector.
Old Apr 20, 2009 | 12:51 AM
the_merv's Avatar
Veteran: Air Force
Everything is good on the Car.. something with that Scanner is messing up. Could be a Cable aswell..we are looking into it.
Old Apr 20, 2009 | 08:24 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Have you connected any other scan tools to the car? As was stated before, make sure you have 12 volts on Pin 16 of the OBDII connector, it is the cig. lighter circuit.
Old Apr 20, 2009 | 09:34 AM
the_merv's Avatar
Veteran: Air Force
It's got 12v..the Fuse & Circuit is good. We haven't hooked anything else to the Car. I'll get with him and figure it out. Thanks guys.
