AEM WB vs. Stock NB accuracy
Hey
I have been working on my tune with the AEM on the right side LT (no exhaust leaks) as the left side there was some leaking going on, got the tune as close as possible with the AEM (one run would be pos. and the next neg. and ended up splitting the difference) I have highflow cats mounted right up to the collectors and the left side went bad and when replaced the exhaust tech said the tune is lean because the cat material was real white and breaking apart because of the lean tune (could this be because the collector was leaking? (QTP headers) got the collector to where there is little or no leaking by using the 2400* patch material, anyway now did a new scan with the NB's (CL, STFT's only) and they said the car was real rich, giving me readings of neg. 10-20 on 4 separate scans....can this be?, I have read some don't think much of the AEM, are they off that much?, I really don't have a third to check other than a local shop with a dyno that uses a sniffer WB.
If I run CL would I not have to use what the NB's want or like now they will be pulling fuel all the time?, I would like to stay CL so I don't have to monitor the tune...if possible.
Thanks for any ideas
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
WB and NB are subject to the same spoofing by
exhaust air. Though different locations might see
it to different proportion, depending on leak location.
If you tuned against leak-bent original readings
then you may have pushed it rich and now it's not
needing that (by the instruments; the challenge is
always in knowing when the instruments lie).
LS1 Tech Administrator
To get the most accurate reading at all loads and rpm with the NB sensors, it's best that you make all your O2 switchpoints 450 mv. Once you've done that, a fresh NB O2 sensor will be more accurate for chasing that perfect 14.63:1 A/F ratio than an inexpensive WB O2 sensor.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
