Security light problem
Old May 7, 2009 | 06:36 PM
vatechguy3's Avatar
Default Security light problem
so, i get in my car this morning and as i'm driving down my street i notice the security light is on. it remained on steady all the way to work this morning. It came on when i drove to a meeting in the middle of the day, and it was on when i drove home this evening. there was no performance change and no issues starting right up as always.
what do i need to look at to fix this?
thanks
tony
Old May 7, 2009 | 07:18 PM
blade2222's Avatar
Same thing happened to me, had a broken wire that went up the steering column to the pickups in the ignition switch. Check there first.
Old May 7, 2009 | 07:42 PM
2001NBMZ28's Avatar
Try cleaning the key first. If it stays on a repair or VATS bypass is in your future.
Old May 7, 2009 | 09:21 PM
vatechguy3's Avatar
can you give me an idea where on the column the broken wire was?
and clue as to what cause it to break?
thanks
tony
Old May 8, 2009 | 07:08 PM
blade2222's Avatar
broke right at the lock cylinder, turning the key causes the wire to rub inside of the cylinder untill it's worn through. I had a lock smith take it all apart. I've since did the VATS bypass.
Old May 8, 2009 | 08:12 PM
vatechguy3's Avatar
did the VATS bypass make the light go out?
tony
Old May 8, 2009 | 09:16 PM
blade2222's Avatar
Yes, the PCM thinks it's reading the pellet on the key.
Old May 8, 2009 | 09:32 PM
Swift_01_z-28's Avatar
So, I have the same problem with my security light, how do I do the vats bypass?
Old May 9, 2009 | 09:24 AM
twitchtwice's Avatar
yeah, this has been happening to me a lot as well. its weird because its random, sometimes it there and sometimes it isnt.
Old May 11, 2009 | 06:38 PM
blade2222's Avatar
VATS bypass http://www.ls1.com/forums/showthread.php?t=61262
