LS1 Wiring harness VS 5.3 Wiring harness
I want to put a 5.3 in my LS1 car. What do i need to change on the wiring harness? can i use the same computer? What sensors are different? I plan on using my fuel rail, injectors and ls6 intake on the 5.3. Thanks
what for? if hes using the long block and keeping everything else from his ls1 everything will be in the same location and everything...there are no external differences between an ls1 and lm7 other then block material...
You won't have to modify anything on the harness and all sensors are the same. You will have to drill and tap the engine block for the alternator bracket. This is very common and there are several threads with pictures on this site explaining where to drill and what size tap.
