tps readings
.6 key on engine off throttle closed 0% throttle angle
.53 engine running throttle closed .53 0% throttle angle
i swapped in a borg warner and a wells. after doing the tps reset multiple times i get the following:
.53 engine running throttle closed .53 2% throttle angle
wtf is going on. im getting .01volts black 5volts grey and .61volts blue with a volt meter.
i put the stocker back in, do the tps reset, and get:
https://ls1tech.com/forums/pcm-diagn...e-problem.html
https://ls1tech.com/forums/generatio...y-problem.html
https://ls1tech.com/forums/pcm-diagn...time-help.html
https://ls1tech.com/forums/pcm-diagn...losed-wtf.html
https://ls1tech.com/forums/pcm-diagn...any-ideas.html
https://ls1tech.com/forums/pcm-diagn...n-running.html
https://ls1tech.com/forums/generatio...tps-issue.html
http://www.hptuners.com/forum/showthread.php?t=20197
http://www.hptuners.com/forum/showthread.php?t=13917
http://www.hptuners.com/forum/showthread.php?t=22756
I am suffering the same issue with my stock TB...
