What are these wires for on PCM?
Old Jun 10, 2009 | 01:16 PM
TedsB4Csled's Avatar
Default What are these wires for on PCM?
Can anyone tell me what are these wires for? Solid purple wire & solid white wire. The solid white one is no longer attached, I don't know if I should mess with it. This is an 02' Camaro B4C LS1...
Thanks!
Old Jun 10, 2009 | 03:35 PM
Solid white wire is the one that's off. Solid purple connected to the green. Should I reconnect the white one? Why are they spliced into the green wires?
Old Jun 10, 2009 | 10:39 PM
I got the electrical diagrams out.... but what are those two wires? Anyone else have this?
Old Jun 11, 2009 | 12:53 PM
Help, please?
Old Jun 11, 2009 | 01:12 PM
2001NBMZ28's Avatar
Are you looking at the pcm pinouts? www.ls2.com/boggs/torques/2002pcm.htm
Old Jun 11, 2009 | 10:03 PM
No not the pin outs. See the solid purple wire on the top pic, with the white male connector going into the brown female connector, that is connected to the green wire. Then there is the solid white wire(above purple) that is broken off from connecting to the other green wire which still has brown female connector. Trying to find out what they are and if I need to reconnect the wire. It's been like that as long as I can remember, but I'm having some random miss fire issues.
Old Jun 12, 2009 | 12:15 AM
Frost's Avatar
It's nothing that is factory...
Old Jun 12, 2009 | 01:15 AM
GA95DCMSS's Avatar
Do you have any extra switches in your car? Take the PCM connector cover off and see what pins the green and green/white wires go to, and that would definitely help you figure out what they're for.
Old Jun 12, 2009 | 08:20 AM
Will do, thanks!
